Old 04-15-2011, 05:42 AM   #14 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by ngrimm View Post
1. Is the curved transition from the air dam to the belly pan a bad thing?
Ideally you'd want a clean separation between the air going underneath the air dam and the air being pushed aside by it - that's where splitter plates come in, forcing the air to go either way.
Without a splitter plate, some air is going to spill underneath the dam.
A more rounded transition should result in a smoother (but slightly bigger) airflow going underneath the air dam and onto the belly pan.
The Following User Says Thank You to euromodder For This Useful Post:
ngrimm (04-15-2011)
