Old 04-15-2011, 12:22 PM   #16 (permalink)
ngrimm
Great advice gentlemen. Would it help the separation if I install a flat piece of 1/8" thick aluminum fastened to the bottom. edge of the air dam that protrudes a couple inches in front of the transition? Also should I bend the corner of the dam to blend with the fender and perhaps use the front half of a fender flare to divert air around the tires? One other thing, I removed some 80's style aluminum running boards. Should I put them back on (I could paint them black) and try fill between them and the sides of the belly pan? Notice in the picture below the vertical flat pieces that that stick out past the fenders. Not sure if that is good or bad.
Name:	Runnig board.jpg
