Old 04-15-2011, 02:05 PM   #17 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by ngrimm View Post
Great advice gentlemen. Would it help the separation if I install a flat piece of 1/8" thick aluminum fastened to the bottom edge of the air dam that protrudes a couple inches in front of the transition?
That would give a clean separation between the air that goes underneath and the air that's pushed aside.
The air dam should only be about as deep as the lowest component that catches a lot of air underneath the belly of the truck.
Making it lower will increase the total frontal area of your truck, and that creates more aerodynamic drag.
Also should I bend the corner of the dam to blend with the fender and perhaps use the front half of a fender flare to divert air around the tires?
Shielding the tyres from the air also helps cut down on aerodynamic drag, but make sure you don't increase the frontal area of the truck too much by doing so.
One other thing, I removed some 80's style aluminum running boards. Should I put them back on (I could paint them black) and try fill between them and the sides of the belly pan?
Basically, anything you do to smoothen the messy airflow underneath the truck should help.
Look for user BamZipPow's Toyota truck.
He's covered the entire side area between front and rear wheels.
Another modified truck to look out for, is aerohead's T100 truck.
