Originally Posted by PLTWstudent
Nothing wears out if you rev match properly, but that kinds ruins the point from an economy standpoint, doesn it?
You need to give it some gas to rev-match (at higher speeds), but a low rpm and speed, it'll be OK just using the clutch.
Besides, it's only a short dot of gas you need to give it when rev-matching.
After that, you go back to engine braking / DFCO right away, and using no gas.
Brakes are easiest to fix
Brake pads are indeed cheaper than a new clutch
![Wink](/forum/images/smilies/wink.gif)
That's why you better let the speed decay first before shifting down.
Looking far ahead on the road, you should be able to anticipate speed changes by lifting your right foot, without requiring shifting down at high speed / rpm.
