Did you remember to set fuses while programming with PonyProg? I had similar problems as chip ran with its internal clock instead of external crystal giving clock signal. Be careful with fuse settings as you might render chip useless with some wrong options enabled.
I wrote down correct fuse settings for atmega168 when I programmed my chip for a first time. Now I can no longer find them. I should have posted them here right away.
