Old 04-15-2011, 03:35 PM   #4636 (permalink)
flores
EV Connoisseur
1Hz flasing is too slow.. should be flashing faster.
The solution for this problem is a few pages back.. you can search for it.
As for the serial connection, are you sure you are using the right caps for the signal converter.. there are some differences between the chips and the BOM has listed different types.. The solution for this is also in the tread.. search for MAX232
