Step back from the graphs a second and think about what you are saying.
How is it that a Dodge Ram with a Cummins engine gets 50% better MPG than the same truck with the same transmission and the smaller and lighter Hemi?
How is it that the VW Jetta with a manual transmission gets 33 MPG where a gas engine in the same car with same transmission gets only 22?
I think there are a lot of “apples and oranges” in the published BSFC graphs.
The only performance downside to the Cummins four is its weight. That engine weighs about the same as a Ford gas V-10.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
