Old 04-16-2011, 03:03 PM   #27 (permalink)
aerohead
down
Originally Posted by ngrimm View Post
So would it be better to raise the air dam a few inches and let the belly pan bend downward under the diff? Also I think I can flip the top front section of the bed liner and use it as a small air dam chin or whatever it is called.
My pan angles down to the bottom of the axle allowing better ground clearance in front of it.Then shallow diffuser behind axle.
Note of caution.ABS is a thermo-formed plastic so you'll want good heat shielding near cat-converter/exhaust pipe/muffler or she might revert to pre-formed sheet,and in turn,buckling the pan.Ouch!
