Old 04-16-2011, 03:32 PM   #29 (permalink)
aerohead
dam
Originally Posted by ngrimm View Post
Here is the front view. Notice I covered the grill to see if that helps I imagine having tires exposed and also the body being open on the sides isn't helping much. Before I can do some ABA tests I need to get my MPGuino recalibrated since I just replaced the faulty fuel pressure regulator which was sucking into the intake. I modified a new one to make it adjustable so I could lower the pressure a little since it was running rich in open loop.
yeah,it would be better if the dam wrapped around to completely shield the tires,but you should see an effect for sure
