Originally Posted by Tygen1
I can't believe all those folks who said Escorts were retarded were completely right? Sweet, my car is so dumb it can be run lean without it even knowing
I do have aa scangauge, but never checked the ignition timing. I did check the O2 output, but it is so ragged it's hard to tell, although it appears to be the same. I'll check timing tomarrow morning, but I won't be able to check it without till Saturday....maybe?
This is good stuff, I'm glad you have seen an improvement Moorecomp!
What color are the spark plugs?
