Old 04-17-2011, 04:14 PM   #5 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
He has a switch that is normally closed, so it's normally allowing continuity of the circuit. When he pushes the e brake button (effing brilliant!), it breaks the circuit from that wire to the injectors.
If you use a toggle, just wire it in line the same way.
The Following User Says Thank You to Christ For This Useful Post:
LmidgitD (04-17-2011)
