Old 05-03-2008, 08:32 PM   #19 (permalink)
brick
Quantum Flywheel?
You know what I'd try, is find some nylon webbing and use that to lace the insulation to the grill. That might even look pretty decent when you are done. If that fails, I would cut a piece of coroplast to use as a backing. You could cut some slits in the plastic to lace the webbing through it.
