Old 04-18-2011, 12:42 PM   #58 (permalink)
jamesqf
Originally Posted by roflwaffle View Post
For instance the efficiency of an SUV at 80mph on the highway is going to be fairly high even if it has poor efficacy.
How so? Seems to me that in its default (i.e. most commonly seen) one person mode, it's pretty inefficient, even apart from the IC engine. You're accelerating a large mass, shoving lots of air out of the way, incurring rolling resistance from big tires...
...in any event I think 70% for EVs is pretty reasonable.
There's also the second-order factors. So for oil you have 100% of a barrel in the ground somewhere in say Saudi Arabia. You need some amount of energy to pump it out of the ground & push it through pipelines to a loading dock, energy to run the oil tanker to destination, energy to run the refinery, more to run pipelines & delivery trucks, and a last little bit to run the pump at the gas station.
I don't know what that all adds up to, but it doesn't seem unreasonable that it'd be in the same range as a 30% grid plus charging loss for electric.
