Old 04-18-2011, 02:09 PM   #9 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by coolhand297 View Post
I have the parts on order to fix the Tstat and a few other cooling system items which I want to change out just for preventive maintenance.
With a bunch of friends, I once rented 2 vans, one of which had the Tstat malfunctioning, and it'd permanently run as if it was cold.
The difference is fuel use was huge.
As for the Carbon hood it was already sold, shed about 10 pounds off the car from the metal hood, definitely not cost effective. And no measurable difference in MPG's.
You'd need to shed a lot more weight for it to show up in mixed driving.
But it can't hurt to do so
The 3 pedal mod is definitely cost effective, just in future maintenance it will almost pay for it self. Since I got it with the taller final drive it makes all the gears longer not just 5th.
If you ever need to swap the gearbox oil - you probably just did - VW apparently has some quality lightweight tranny oil that brings down fuel use as well.
Another fringe benefit, along with lightweight engine oil, but it seems to be helping me.
