Old 04-18-2011, 03:24 PM   #40 (permalink)
bobski
'91 CRX - '91 Honda CRX DX
90 day: 34.91 mpg (US)
Originally Posted by steffen707 View Post
Can you just de-solder the buttons and the lcd and then solder on long wires and run them back to where they were soldered on the board?
Yes. None of the signals are a high enough clock speed where wire capacitance could be an issue. The only possible problem would be electrical noise. Just avoid running the wires past any motors or high voltage items and you should be fine I imagine. If you still have noise problems (erroneous input, glitched characters on the LCD), try wrapping your extension wires with a layer of aluminum foil and ground the foil.
