Old 04-18-2011, 05:38 PM   #60 (permalink)
jamesqf
Originally Posted by roflwaffle View Post
In the strictly thermodynamic sense a fully loaded tractor trailer will be more efficient than a prius...
Still a bit puzzled, but I'm not sure the highway-cruising SUV doesn't lose out there, too. That is, it's got a big engine (for acceleration, towing those 10,000 lb boats & camping trailers, etc), which in highway cruising would likely be running far from its optimum BSFC, so inefficient. Whereas diesel semi (as you know if you've ever followed on up a long grade) has engine HP more closely matched to cruising load.
