Do you have a medical reason for needing an automatic? if so then look for a civic HX with the automatic, although it's not going to be a hatch back, it's not going to get the same kind of mileage as the manual transmission and you are going to spend more money on repairs because the automatics don't hold up as well.
But you are correct, the Civic VX was never made with an automatic, so if you found two... then I don't think anyone can say what the car really is, if you want to know if it's the VX engine look at the engine block, right under the distributer there is a flat spot with the engine number stamped D15Z1, you can also do a search on here, Tomo started a page with VIN decoding info for civics.
