Originally Posted by TomO
Just make sure that if you use the "Great Stuff" brand of foam to allow it to fully cure the 24 hours it requires before cutting/shaving/shaping it. That way the foam is consistent and will not expand further once you cut it. Ask me how I found this out the first time I made this bumper and only waited 2 hours
How is it holding up?
Also, the CX manifold has the same design just with a single wire 02 sensor.
It only took me 14 years, two EG sedans(one B swapped), an RSX-S, a 90 accord, an 07 Fit, and a 99 integra, to finally get my first EG hatch!!!! Isn't that where us Honda guys are supposed to start?
