Originally Posted by imzjustplayin
there's actually two clutch switches.. one when you fully depress the clutch (starter interlock I guess) and one when you release the clutch. Cars today all have the switch when you fully depress the clutch, it's the one when you release the clutch that is unique to the VX/HX cars..
So has anybody figured out if the ecu operates properly without the b7 ecu pin hooked up? Also, does this pin see voltage or ground when the clutch is out?
Can any vx owner out there unplug this clutch switch and tell the rest of us what happens if its unplugged?
If it is only activated when the clutch is all the way out, you could just feed it 5 volts or ground, whichever it is suppose to see, all the time and then not worry about it.
