Old 04-19-2011, 04:54 PM   #24 (permalink)
Joenavy85
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
Originally Posted by justjohn View Post
Hahah. I read it. I just don't get the part about load capacity going up by a greater percentage than tread and how that translates to lower RR.
you transfer the power to the ground via the tires, that power/energy will deform the rubber (make the raised parts of the tread flex), the more flex the more resistance, when you spread out the contact patch you reduce the flex on a given area. the downside is that when you use wider tires you COULD increase your frontal area, depending on the ride height of your car and how much tire is exposed
The Following User Says Thank You to Joenavy85 For This Useful Post:
Xist (09-14-2014)
