Thread: Ultra Lean
Old 04-20-2011, 12:57 AM   #37 (permalink)
theycallmeebryan
2003 Ninja EX250 - '03 Kawasaki Ninja EX250
90 day: 78.57 mpg (US)
Saturn - '99 Saturn SL1 Base
90 day: 47.27 mpg (US)
Originally Posted by richard_lyew View Post
hahahaaa as for you sir you are just a cereal box tuner that does the same thing that have been done for years and still doing(nothing new). the (+) side of tuning is NOTHING compare to the (-) side of tuning. i bet if you should try to tune on the lean side you would burn soooooooooooo many engines because its not what you are used to LOL. what im doing is totally new to you that's why you don't understand and maybe next year you will start to understand a little more. this forum has a long way to go but ill be here.
Your videos are proving nothing. I can hook up an Apexi unit to any car and have it say whatever the hell i want it to say (for example, your rpm's are 1/2 of what they really are).
BTW, what's so special about what you are doing? You have no way of controlling timing, so all you are doing is taking fuel away. How can you possibly call that pro tuning?
I've tuned on the lean side many times and all my engines were fine. Good quality after market computers with high resolution fuel and ignition maps allow you to do that. Couple that with sequential injection control (ability to control the pulse width of every individual injector separately), wideband inputs for each cylinder, and EGT's for each bank, and you have enough information to push the limits. Nevertheless, a "pro tuner" will know that the lean threshold is dependent on the engine configuration.
We the trustworthy members of Ecomodder.com are not newbie bashers.... but when a newbie comes riding in on his sparkling unicorn, we make sure others aren't glamored by it, unless they can prove the unicorn is real.
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
