Old 04-20-2011, 01:39 AM   #4646 (permalink)
mora
Golfwagen - '89 Volkswagen Golf mk2
90 day: 107.14 mpg (US)
Ponyprog has a button called "Security bits". It doesn't talk about fuses. You also might need some understanding in binary and hexadecimal systems.
This link explains a bit (fuses and bits, hehe):
Programming AVR fuse bits – oscillator settings - Scientific, embedded, biomedical, electronics contents.
You might want to use hex-to-binary converter to be sure about which fuses to set. Please correct me, but I get that F8 stands for EXTENDED part, DC for HIGH and F7 for low.
- EXTENDED (F8) = 1111 1000
- HIGH (DC) = 1101 1100
- LOW (F7) = 1111 0111
Now every bit has a "name". These are listed in Atmega datasheet if I remember right. Ponyprog lists fuse bits with names like CKSEL3, CKSEL2, CKSEL1, SPIEN etc.
It might be better just to take a simple screenshot of PonyProg security bits window with correct bits set and put it here for everybody to see.
The Following User Says Thank You to mora For This Useful Post:
teraamper (04-23-2011)
