Originally Posted by RobertSmalls
The Insight makes this an easy project, because it has a sensor that reports when you're in Neutral, and it already has engine restart logic programmed for you. It might be harder to detect Neutral on other cars. You can't rely on the clutch switch, because it's only closed when the clutch pedal is all the way to the floor.
Good points all around.. I'm thinking this might be easier on a motorcycle-powered car: after all, motorcycles already come with a neutral indicator.. Shifting from 5th or 6th down to neutral, then back up again for when the engine restarts is a pain in the butt though.
Are there any workarounds to the clutch bearing issue?
