Originally Posted by steffen707
Well my civic only has 1 clutch switch, and thats when the clutch is all the way down to the floor.
So i would have to be tricking it in a way. Because the other vx one only activates when the clutch is all the way out right?
So, can somebody tell me is the b7 pin suppose to see ground or 5volts when the clutch is not depressed?
Are you sure there is no switch there? What do you do to adjust the pedal height? Maybe you could take some pics under there.. Seems odd you wouldn't have one.
