Thread: Ultra Lean
Old 04-20-2011, 04:28 PM   #51 (permalink)
richard_lyew
Originally Posted by UFO View Post
When do think you can cut the gasoline completely and drive only on water?
im planning on driving at -50% soon and rich too them i can put a switch on my gasoline pump and a solenoid on my gasoline line. going to upgrade to a high AMP PMA first to have less drag on the belt them make 3 high output cells. in all i will have 4 cells but only 2 will be used under a air flow lower than 13.0 and over that the 3 will kick in then if i go 16 or 17 that all 4 will run at full blast.
for now im just taking it step by step and do all the little tweaking. when i just started this whole HHO thing i couldn't even idle over -15% and look at me now driving at -40%
