Thread: Ultra Lean
Old 04-20-2011, 04:39 PM   #53 (permalink)
richard_lyew
Originally Posted by Phantom View Post
I would assume that he gets AFR by calculating it from Speed Density mode but I assume that that is off. The AFC see ( ZZ Performance ) scales the MAF frequency telling it that there is less or more air depending on how the PCM calculates load and timing both might be off due to this since the car would be running in SD mode and using the MAF I assume that that was the normal config for the engine to run.
If you are not modifying the PCM but tricking sensors then you are not tuning. If you are running lean you should have a WB02 or at the least a EGT sensor to monitor the temps. If you get to hot it can burn up the exhaust valves and possibly throw a chunk in to the cat of let it dance around in the cylinder.
I do some PCM tuning and am looking to later work on running a hybrid open/closed loop system for lean burn when trying to keep emissions close to stock IIRC that would be running 15.5:1 to 15.7:1 I might be wrong on the AFR but do not have time to look it up as I'm late for class.
i had a EGT installed but realized that base on my MAF meter reading the EGT only got hotter than normal when my MAF would be in the high scotch or in lean where the lights are red. so when tuning i keep my A/F lean if the air flow is below 15.0 and if it gets higher then fuel will be added to match the amount of air so i don't burn the valves. i also found that because the hydrogen shortens the BTU of the fuel mix it can run lean and not have that high of a temperature when compare to only gasoline.
and because of this very short BTU and high octane, i had to advance the timing a bit. thanks for the heads up on the EGT but someone had mentioned it before and i installed it but realized after that i could base the reading on the MAF meter.
and everything is adjusted including the PCM. NEED pinout for 2004 Ion ECU - SaturnFans Forums
