Originally Posted by richard_lyew
when my MAF would be in the high scotch or in lean
uh, do you mean Stoich(stoichiometric)?
make sure you are clear about what you are saying to avoid looking like an idiot. i say that because Scotch is a brand of tape, and it's also what sits in a bottle on top of my fridge.
A/F lean if the air flow is below 15.0 and if it gets higher then fuel will be added to match the amount of air so i don't burn the valves
air flow doesn't drop below 15, you air/fuel ratio does. other than that, it sounds just like an ECU.
