Old 04-21-2011, 01:38 PM   #34 (permalink)
JMac
Musician w/ Light Wallet
SeaBiscuit - '98 Honda Civic DX Hatch
90 day: 39.99 mpg (US)
He has replaced the stock exhaust. That could actually disable lean burn somehow?
The short answer is: I'm not completely sure, but if they pulled the catalytic converter off that car, then I'm pretty sure lean burn will not be functional. A lot of those guys will pull the cat out and put on a "test pipe" to supposedly get a little more horsepower. I'm pretty sure not having a cat is illegal in every state, but if you don't have inspections you may never get caught, unless of course you move to a state that does.
Anyways, I think there are some sensors in the cat with the HX which tell it yes or no for lean burn. Can any of you HXperts comment?
HTH,
JMac
The Following User Says Thank You to JMac For This Useful Post:
justjohn (04-21-2011)
