Old 04-21-2011, 08:15 PM   #1 (permalink)
justjohn
Black Beauty - '13 Hyundai Elantra
HX advice (catalytic converter needed for lean burn?)
Notice: my other thread I sort of branched off and started talking about this. If a mod wants to split the thread or move those posts over here feel free, just making a new thread for the moment.
Originally Posted by justjohn View Post
Going to check out the 96 HX on Friday. What sorts of things should I be looking for? My car knowledge is improving, but still pretty basic. Anything in particular that you guys know of that tends to go bad on these or anything like that?
Originally Posted by JMac View Post
You might ask around about how to make sure it's lean burn is working. Not sure you'd be able to tell just from driving it. I'm sure the community can help us with that. In order for lean burn to function correctly, the HX needs:
*The special air sensor
*The stock ECU
*The special catalytic converter setup
Is that all correct?
JMac
Anyways, I think there are some sensors in the cat with the HX which tell it yes or no for lean burn. Can any of you HXperts comment?
