Old 04-22-2011, 09:22 AM   #4 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
You can also try the top of the fridge, if you don't want to take your bread dough outside, the fridge is also right there in the kitchen, the compressor and coils tend to keep the fridge warm.
I personally like using a heavy ceramic bowl that holds the heat in and I warm it up by using water that is a bit to warm at first so the bowel gets warmed up while cooling the water, then tossing a towel over the top helps as well.
