You know you might be right, I'll have to check that. It appears the VSS signal comes from the ABS sensor on the rear differential and is probably just inductive. I may play with a Schmidt trigger to condition the signal so it at least lowers the speed at which it stops counting. If I could get it down to 5 mph or so I think that would help. Not sure if anyone has done that before.
