Two things I would try are removing R6. If that does not help then try installing a resistor in parallel with D1, try values between 20K and 50K.
ABS sensors are mounted at each wheel and often do not read down to zero. The sensor in the differential should be for speed and must read down to zero to keep the odometer accurate.
Mike
