You may not have surmised that I'm just experimenting with extremes and will probably cut the air dam down some to see what is the least I can use and still achieve better mpg. That's why I made the side skirts short so as not to not loose ground clearance under the center where it really counts. I can take all of these mods off in 10 minutes and go four wheeling but not with these tires. Will post mileage results once my testing determines what if any is from the aero mods versus driving style changes.
