So, just reducing the amount of fuel going through the injectors won't work for certain cars, unless it is paired with hacking the signals from a few sensors, I guess.
But what if the injectors are swapped for something with similar flow, but with better atomization (which is what the thread's starter had in mind, I believe)? Let's say that my engine has 5-point injectors, while a new version of that engine has 6-point injectors. Would my FE benefit from the upgrade? Would I also have to swap the ECU?
