Thread: Saturn bellypan
Old 04-23-2011, 03:57 PM   #1 (permalink)
orbywan
Saturn bellypan
Hi,
This is my first post with ecomodder so here goes. I have a 99 Saturn 1.9L DOHC 5 speed. Great car. So far I've blocked off the front grille completely (no overheating even with the A/C on), made covers for the headlight nacelles, removed the side view mirrors and installed cameras instead.
I posted some photos of some of the mods, I hope they load OK.
My average 14 mile commute has been 43.2mpg on the scan ga. before the mods. After the mods I'm still collecting data but the average is around 52-53 mpg.
So, the reason for the post is I'm thinking about a bellypan since the body is about as low drag as it's going to get without major surgery. I found the post by lovemysan concerning belly pans. He said he used polyboard and like it better than coroplast, but I'm not sure plastic is the way to go down there.
Anyone have any suggestions for the bellypan material? Aluminum sheet will have to be ribbed to keep it from rattling, etc., but problem I would think with anything plastic is the cat will melt that in short order.
He refers to Hucho's post on belly pans, can't find it, does anyone have a link to that? Any info on belly pans would be greatly appreciated. Thanks!
Name:	Front mods II wb.jpg
ID:	8214   Click image for larger version
Name:	Front mods wb.jpg
ID:	8215   Click image for larger version
Name:	Before left side cam wb.jpg
ID:	8216   Click image for larger version
Name:	Left sidecam wb.jpg
ID:	8217   Click image for larger version
Name:	Upper Tailcam wb.jpg
The Following User Says Thank You to orbywan For This Useful Post:
Piwoslaw (04-23-2011)
