The grill block was causing the engine to overheat so I removed it will have to re-design and try again. I'm thinking that since I'll have to pull the engine apart to do the cam swap I want to swap the crankshaft as well, something with a longer stroke to increase displacement, and shave the head for more compression. Also an upgrade to newer lighter pistons. Any thoughts on if this would be beneficial or not?
Recycling is cool, and MacGyver IS a god!
