Thread: Saturn bellypan
Old 04-24-2011, 12:42 PM   #11 (permalink)
theycallmeebryan
2003 Ninja EX250 - '03 Kawasaki Ninja EX250
90 day: 78.57 mpg (US)
Saturn - '99 Saturn SL1 Base
90 day: 47.27 mpg (US)
My 99 Saturn SL1 does the same RPM hike when clutch is pressed in or shifting to neutral. I've found that it's ECU and IAC related. Disconnecting the battery overnight has fixed that problem, but it seems to be coming back after about a week. Since i do a lot of pulsing between 1800-2300rpm and EOC gliding, i think the ECU is thinking that i don't know how to drive and is trying to hike the rpms to compensate for early shifting?
I suppose, like others have said, putting the IAC on a switch could solve the problem. Or, just disconnecting the IAC all together and manually adjusting the idle speed. I'm going to look in to it further as I,too, feel like it is hindering my fuel economy.
I really like the mods you did to your front end. It looks very clean. All i have right now is clear window seal tape blocking the radiator . I've been hitting between 43-46mpg this winter, and hope to break 50mpg once the temp warms up here.
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
