Old 04-24-2011, 05:05 PM   #177 (permalink)
jackbauer
jackbauer's Avatar
Just thinking out loud regards powering the board when on charge. I don't use a dc-dc. I have a seperate 12v battery and charger for the accessory systems. I have the lcd module powered via a relay from the ignition switch. I also have a mains powered two pole relay that i use one pole for traction inhibit when on charge. If i wired the spare pole in parallel with the 12v relay it would activate when plugged in and draw power from the 12v charger. I'll give it a try. Might save a bit of rewiring.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
