Sounds like it would work. For me, the AC powered supply was an easy way to provide power when ignition was off and charger was on. This setup could even be powered by the accessory battery directly since a 160mA load for a 10 hour charge cycle wouldn't be much of a drain. Just need a switch or AC relay.
