Old 04-25-2011, 03:31 PM   #28 (permalink)
cleanspeed1
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
Originally Posted by jtbo View Post
Mechanical Lucas, Bosch would be better, but of course car had not that one. Lucas is PITA to tune as screws are hidden under blind plugs and so that one can't see there without tiny mirror.
There is not much electronics in a car, old fashion engine with old fashion mechanical management, that I kind of like, less to worry.
edit: I don't know if I did this horribly wrong, but I got these:
Perhaps not so good improvement in reality, but at least there is some change.
Ok, so it's a Lucas CAV ( rotary ) pump, similiar to the one used on the early Cummins 5.9. It may be a pain in the butt to get to the screws, but there is gold in changing the settings. Add more timing but cut the fuel back. If you are not comfortable doing it, you are in the best place to do diesel tuning. Between the Germans and the Finnish, there has to be someone that can optimize the torque curve for lower rpm operation.
The Following User Says Thank You to cleanspeed1 For This Useful Post:
jtbo (04-25-2011)
