Old 04-26-2011, 02:44 AM   #18 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
The actual relation between installed power and averaged actual fuel consumption, as averaged from the database of spritmonitor :
Power vs. mileage - Spritmonitor.de
The fuel consumption numbers above the bars are in Liters per 100km (62.1 miles), so higher numbers also mean higher fuel consumption.
Engine power in kW is given below the bars, and indicates a range from -10 to +10 kW around the given value.
ID:	8234   Click image for larger version
The Following 2 Users Say Thank You to euromodder For This Useful Post:
MetroMPG (05-02-2011), Piwoslaw (04-27-2011)
