Originally Posted by ted frater
IF your Golf is NOT common rail ecu controlled fuel injection system, and its has an ordinary Bosch roatary fuel injection pump you can go to 10% new veg oil into your normal diesel fill.
This slows he burn rate and thus increases the mid crank angle combustion pressure with less fuel needed for the same speed.
Do your research tho before trying this mod.
coast up to all intersections and traffic lights, use thekes as little as possible.
He's got a PD engine, and vegetable oil is NOT recommended.
http://forums.tdiclub.com/showthread.php?t=315809
