Lou your high side igbt is shorted? What i would suggest is to try again but leave out that diode system you were using and just short gate to emitter. I've done this with 3 controllers to date and no issues. Currently doing it to 4 and 5 right now.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
