Old 04-26-2011, 04:32 PM   #14 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
I would say a higher flowing exhaust will help unconditionally if you keep your foot out of it.
It has already been mentioned that reduced back pressure means a higher manifold vacuum to maintain the same power output. A higher manifold vacuum means that you will have a greater crank case vacuum via the PCV valve. This will reduce the amount of air being pushed around in the crank case and reduce drag on the engine. A higher manifold vacuum also means better fuel vaporization (but this results in negligible improvements to the percentage of it burned).
As to whether it will give a 3 to 5% mileage gain, I doubt it. When cruising at speed flow rates through the engine are low, and thus the back pressure is low. Improving the flow of the exhaust will lower back pressure a tad, but squat minus squat is still squat.
It should help but I doubt you will be able to measure it with any certainty.
