Old 04-27-2011, 04:01 AM   #4 (permalink)
andylaurence
Roadster - '04 Smart Roadster
Thanks guys! First of all, to answer the rules question, I'm pretty much free on what I can do with bodywork. The sport is goverened by the MSA and the regulations are in the Blue Book, specifically the sections on sports libre cars in sprints and hillclimbs and vehicles. That boils down to:
Maximum width - Measurement between the outer tyre walls of the front or rear (whichever is the wider) + 20cm
Maximum rear - 150cm behind overhang rear wheel axis
Maximum height - 90 cm from the ground (open cars)
Maximum front - Not to exceed the top aerofoil height of the front wheel rim
Maximum rear aerofoil - 90cm from the ground height (closed cars)
The NACA ducts on the front are not functional. I believe they are used for brake cooling in endurance racing. I'm not sure of the function of the holes at the front. My splitter is not standard and the original car may have a front diffuser that uses these holes.
Boat-tailing behind the rear wheels sounds like an interesting idea I'd not thought of.
The underside of the car is completely flat (aside from a few rivets) from the front of the splitter to the start of the little diffuser that starts at the rear axle. I've considered making the diffuser bigger as that will bring it closer to meeting the top bodywork, bring more downforce and start to work with the rear wing.
A boat-tail behind the driver's head sounds a good bet, along with smoothing off the box on the rear engine cover.
The mirrors are a quick win - I don't need them as cars run against the clock, not head-to-head and the regulations do not require them.
The cockpit opening must be at least 85cm wide, so I could close it a little.
How would I securely fair in the wheels? I guess a sheet of perspex and some cable ties would be a good start. What about wheel balance? At 130mph, wheel balance is quite important! Brakes don't get very hot in sprinting as the longest event is 3.3 miles, including just 9 presses of the brake pedal from cold.
I'm impressed at the detail you guys have picked up so quickly. Some stuff I'd just never noticed. Thanks for the suggestions. Time to get some foam...
