Now, about the electric motor.
I've used 36 volt, 750 watt electric motors on bicycles and tricycles. If you pedal a lot and only use the electric motor on hills you can expect about 20 miles before the batteries require 4 hours of charging. Continuous motor use will reduce that to about 5 miles or less.
Lithium will go farther and charge quicker but not much farther and not a lot quicker.
