Old 04-27-2011, 02:15 PM   #85 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by jason1973tl View Post
O.K. first point. You need to watch a few vids on the Aptera. The shell is designed to be so strong an elephant could stand on it.
In theory it could if the weight was evenly distributed. A chicken egg can support over 25 pounds under the same circumstances. That doesn't mean that gluing 160 eggs to my car will make it safe.
I'll believe their claims on safety when I see crash test results conducted by the Insurance Institute for Highway Safety.
So far all Aptera have produced as far as safety is claims, marketing, and a limited computer simulation.
Second, I believe the reverse trike design makes it more stable than older tadpole designs, and I believe this design is much more likely to spin out than even a regular car. Just watch a few videos on the T Rex.
The reverse trike makes it more stable in braking which is a good thing but not everything. Lateral stability will still suffer from the trike design. The only way to improve it is to move the center of mass up toward the two front wheels. Unfortunately the more you do this the less control and directional stability the back wheel provides. If you move the center of mass too far forward the car will flip over when applying the brakes.
Third and most important. The Lithium battery that needs coolant are the lithium ions referred to as lithium cobalt oxide. Those are the thermal runaway batteries you are talking about. Anybody looking to use lithiums should look at Lithium Iron Phosphate. It is a much cooler running, much more stable and longer cycle battery chemistry than the others you are talking about. All of the home converted electric cars I know of using lithiums are using LiFePo batteries. You can find a dozen or more websites selling them now. They are the large format rectangular, yellow, blue or white batteries you may have seen pictures of.
All lithium ion batteries types have issues with fire safety. Its the nature of the chemistry. Some variants have reduced the danger some but they can't eliminate it. The highest risk of fire from them is when recharging, but they still can go off seemingly for no reason when not in use.
The main problem is that small metal filaments form in the electrolyte. If you get some of them to short from the positive side of the battery to the negative side of the battery it discharges the battery and it over heats and explodes.
