Originally Posted by some_other_dave
Your CRX Si figures are very close. I find that I'm pretty much dead-on 500 RPM per 10 MPH in my 1990 CRX Si.
Curiously, the Si has the same gearing as the "standard" 5-speed CRX (AKA the "DX") but a different ring/pinion ratio so the Si gearing is effectively much lower.
-soD
2 problems with your statement.
1. the x axis intersects the y axis at 15mph
2. your idle should be like 700-900 i would imagine, so it would probably be inacurate if you were trying 5th gear at 500 rpm.
Any VX drivers out there know their tire diameter and can tell me if the graph for VX is correct?
