Old 04-28-2011, 07:13 PM   #7 (permalink)
some_other_dave
Originally Posted by steffen707 View Post
2 problems with your statement
What I meant is that for every 10 MPH of road speed, I turn 500 RPM. Not that I drive at 10 MPH at 500 RPM. I will drive it at ~1500 RPM at 30 MPH, 2000 RPM at 40 MPH, 2500 RPM at 50 MPH. (And not much faster than that.)
Granted this guy could be using non stock tires...
That, at least, is not a factor. The speedo reading is taken from the transmission, so it merely is a measure of how fast the drive axles are spinning. To get an actual MPH figure, the speedometer assumes a given tire size; if you change to larger-diameter tires then your speedometer will still read the same MPH for a given RPM in a given gear. Your actual speed will be different, though.
The other concerns you mention could be problems, but from hondaguy72's post it sounds like they aren't.
-soD
