Originally Posted by jakobnev
Accelerating too slowly actually hurts FE, there are some threads about acceleration strategies and a good one on brake specific fuel consumption. I suggest you look them up. Also: some automatics need a little coaxing to get the best out of them, like tricking it to shift up by lifting off and then depressing the gas pedal again as much as possible without it shifting down again.
+1
If you have a Scangauge / MPGuino, you will see this.... slow acceleration is bad because you are consuming a higher rate of gas, in a lower BSFC island, and for a longer period of time.
Autos aren't the greatest for FE either and ideally you would swap a manual into it.
Also, since you have just had the engine rebuilt, make sure you run it in hard if you want it to bed in properly and not use any oil.
Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
